1 - 5 of 5 Posts
Does anyone know how to remove the rear wiper arm?
I need to make adjustments to mine and can't figure out how to get it off ...
If i remember correctly it is slid into a plastic U tab and you need to give it a bit of a pull to slide it out im not sure i have to look at mine to refresh my memory ill check and get back to ya
peace
Oh im sorry i miss read what you wrote
to remove the wiper arm.........
at the bottom of the wiper pull up and about an inch of the wiper should fold up and back exposing a nut just losen the nut then pull the wiper off. You may have to give the wiper a bit of a tug becouse it is probably pretty snug on their from the nut. Then make your adjustment and then pop it back on. Hope that helps.
peace
1 - 5 of 5 Posts
