1 - 12 of 12 Posts
Being a taller guy, I have always had rear view mirrors in my way, especially on roundabout/clover entrances on to freeways. I always have to duck down to see, and it has always bothered me in fear that there will be someone/something there before I have a chance to duck down and look.
So a few months ago I took off my rear view mirror in an attempt to raise it closer to the roof. I botched the process and after a week I was happy with a clear windscreen. So I readjusted my side mirrors and I have a fine view behind me (reversing I have always turned and looked back so that was no issue.)
Now I am looking to see about installing a rear view camera as my radio is on the way out anyways (volume knob is non-responsive periodically)
My question is not so much how, but the legality. California law states two mirrors, but this law was ratified in 1970: V C Section 26709 Mirrors
Has anyone pulled this off? Or does anyone have any insight into these laws, professional or otherwise? I'm illegal now, so I suppose this could only be better.
I was hoping to completely delete the rearview mirror to have a clear windscreen.
How tall are you then?
I am 6'2" and the mirror is never anywhere near to being in my way.
in CT a center rear view mirror is not required.
if a center mirror was required of all vehicles, trucks would have a tough time.
edit: from the ca vehicle code.
Mirrors
26709. (a) Every motor vehicle registered in a foreign jurisdiction and every motorcycle subject to registration in this state shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such vehicle.
Every motor vehicle subject to registration in this state, except a motorcycle, shall be equipped with not less than two such mirrors, including one affixed to the left-hand side.
(b) The following described types of motor vehicles, of a type subject to registration, shall be equipped with mirrors on both the left-and right-hand sides of the vehicle so located as to reflect to the driver a view of the highway through each mirror for a distance of at least 200 feet to the rear of such vehicle:
(1) A motor vehicle so constructed or loaded as to obstruct the driver's view to the rear.
(2) A motor vehicle towing a vehicle and the towed vehicle or load thereon obstructs the driver's view to the rear.
(3) A bus or trolley coach.
(c) The provisions of subdivision (b) shall not apply to a passenger vehicle when the load obstructing the driver's view consists of passengers
i fail to see anything mentioning a center mirror. as long as you have your R+L mirrors you should be fine.
Why not just keep the mirror off? What can possibly be so interesting behind you?
Then again, thats what I say about the road in front too ^_^
Discussion Starter · #7 ·
I'm 6'1" and for whatever reason, the thing is freaking annoying, mainly during touge or spirited driving. My seat is slammed as low as it will go. If I gel my hair, giving me an extra 2 inches it will skim the top. How close are you to the ceiling poison beef?
Viggenkid: good point. Two mirrors including the driver side means that as long as I have the passenger, I'm good to go.
I'm 6'4" and have more of an issue with the a-pillars then the rear view. And I have an NG, the a-pillars are bigger on an OG.
Adrenaline, how the hell did you get your rearview mirror off in the first place? I actually want to remove mine to install an autodim mirror but I've no idea how to do it without cracking the glass...(convertible, it's glued right to the glass?)
I'm 6-3 and have no issues, I also have radar detector under the mirror, but if its legal and you don't like it then get rid of it. I removed mine from another car using fishing wire.
Discussion Starter · #11 ·
Weird, I'm thinking that my seat doesn't adjust the entire way down.
Supergreesol, I have a 5 door, so my mirror is attached to the roof, I really have no idea how to safely remove it from the glass. Seems like heat is the best way: How to Remove Rear View Mirror Mount | eHow.com
I'm 6'3
I feel your pain.
1 - 12 of 12 Posts
