1 - 13 of 13 Posts
I've got one I think. But I think one of the little "fangs" that helps locate the dowel on the trans mount is busted. How fast do you need it? It's at my in-laws but I may be able to get someone to bring it to me.
well the sooner the better....but I need one in good shape as I'm having issues with my current one (which bolts to the rear) because the threads back there are screwed up. using the newer mount will access different threads and fix my problem.
Discussion Starter · #9 ·
I dont need the MOUNT, I need the BRACKET that holds the rear motor mount in place. So in the pictures posted above its the mount that the first picture bolts too.
Discussion Starter · #11 ·
well i have the earlier style transmission which bolts to a different part of the transmission. The threads are screwed up and changing to the newer bracket allows me to use different threads on the tranny.
1 - 13 of 13 Posts
