1 - 20 of 38 Posts
Just picked up a 2000 93 Viggen and am looking to install my nakamichi single din deck. I have been looking for a dash kit, and cant seem to find anything specific for the saab. Crutchfield has a honda kit, and metra has some generic one that is recommended. Which one do you guys use that looks good? Crutchfield wants $20 bucks. I know there is crazy markup on this stuff but at that price I might as well give my local best buy some biz. Where do you guys get your pockets and wiring harnesses?
Does the pic not show all the parts included? Does it come with hardware to secure the radio above that fill pocket? If so Il order it from there.
Thats all it comes with. When I put mine in my ng900, the pocket snapped in below the SID, and I used the cage that came with my head unit to mount the radio.
Get the pocket from Genuine Saab like chevyman posted. Here it is installed in my NG900:
Pimp and I are going to start a don't cut the wires club.
Harness is a must. Goodluck with installation, always remember, with saabs always something fits different! :)
Discussion Starter · #11 ·
Thanks guys. That makes me feel better about the kit now. Il def. be using a harness also. As far as door speakers go....I have some focal utopias (6.5") that Im hoping will fit nicely without much work. I plan on taking off the door panels to see what im working with as far as space and stuff this weekend. Any tips?
There are a few screws along the bottom, one in the handle, one in the pull. After that just give the door a panel a pull and it should pop off.
(I think thats all the screws, I'm doing this from memory)
there are also a handful of those godawful plastic rivet things. Try not to break them, but you probably will anyway.
them stupid plastic rivet things. Between the doors and c-pillars I have almost non left.
Any tips?
Don't use the OEM plastic woofer mounts - I installed some good quality dynaudio drivers in them and they shattered - realy they shattered like safety glass. really strange. Take the time to make some plywood/mdf-sandwich rings. It takes some craftsmanship because, well, you'll see - it's an odd fit but do this up front to save a hassle later.
As for the plastic bits - I too broke a few. do it when its warm out or carefully use a heat gun on the areas to warm up the plastic so it bends instead of snaps. The little plastic sail panels where the side view mirror adjusters are especially.
I did not do this on my 9-3, but a shop did it on my old 900 - instead of trying to thread better quality speaker wire through the oem wire harness into the door(it's a no-go - or at least VERY difficult), drill a small hole just below to thread good quality speaker wire in. One hole on the door and a matching one a bit higher up or lower down on the door frame. Use rubber grommets to prevent the metal from cutting the wire. Silicon it up.
Discussion Starter · #18 ·
Ive been planning on some mdf rings to mount them anyway because I think depth will be an issue with these speakers(focal utopia 6.5s)....does the window come down and interfere? Im going to start with the install this weekend hopefully.
I've had Polk/Momo MM6's in my doors for 5 years using the factory plastic buckets. I did have to remove some plastic from the back and I also had to notch the door a little bit to clear the binding posts. but they fit fine and have held up great.
http://www.polkaudio.com/caraudio/specs/recent/mm6/
They are 6.75" in diameter.
Mounting Depth: 2-13/16" (7.14cm)
The current line of Focal Utopias have a 72mm mounting depth. Mine are 71.4mm. You should be fine.
1 - 20 of 38 Posts
