1 - 6 of 6 Posts
I have a 2005 Saab 9-2x with everything factory, including the radio. Today on the way to work the radio froze -- won't turn off, change station, change volume, operate the CD, etc. even after the ignition was turned off and the key removed.
With the key removed and the radio playing, I pulled the radio fuse -- the radio continued to play. I had to pull the positive battery terminal to turn off the radio.
I don't think it is the ignition switch because even with the car running, not changes on the radio, it stuck on same volume and station.
My guess is the radio is shot. :censored:
It has happened to me too. Radio froze no response to volume, CD, etc. You need to wait 10-15 min. It will turn off automatically.
Hmm, that's strange, everything should have been off once the ignition was turned off as well. Have you been noticing any weird static before the radio froze?
1 - 6 of 6 Posts
