1 - 20 of 29 Posts
Premium Member
look at it again.. the belts are at the firewall and the clutch is in the front...there is a chain off the crank that drives the transmission
yea, the engine sits like it could be RWD but it's FWD
Common mistake for people not familiar with the cars.... pop the hood.... & many times they as is it RWD
Years ago I took my SPG to a dyno & they were in the process of setting it up to dyno the rear wheels..... they were shocked when I umm..... FWD
I actually saw a rwd classic 900 once! It was refered to as "Saabstang" it had the powertrain out of a mid 90's mustang. It was just one of the creations that came out of lincoln way!
Super Moderator
Oh sure, there are a few. The Saabstang belongs to the dinks at Automotion in Billerica MA.
ya all of the older Saabs are front wheel drive, only the very new XWD aren't. If the belts/pulleys are towards the fire wall the motor is in there correctly. One of the reason's that Saab c900s are so good at handling and don't have torque steer, is that even though it is a front wheel drive car the drive output is totally balanced to both wheels, as opposed to a normal FWD car which has the pulleys toward the side fender which makes uneven torque to one wheel or the other, which under hard acceleration, will rip the steering wheel out of your hands if you don't have a good grip on the wheel.
Deez Nutz
The TL I own has 270HP, FWD, and no torque steer.
Now, the 9-3's I used to have...is another story.
1 - 20 of 29 Posts
