1 - 3 of 3 Posts
I'm planning on flushing my cooling system very soon since my Coolant Level Low light has been coming on. I've read that many of you recommend using Mercedes-Benz coolant. I was searching for info on coolants and came about EVANS NPG+™ COOLING at http://www.evanscooling.com/html/auto1.htm. Has anyone every used this in their Saab before? Are there any other coolants people recommend? I just want to make sure I use a coolant that won't harm my 1995 SET. Any information or comments are much appreciated.
hey, i know how you feel, i'm looking to get my coolant changed too, also flushed cause it's looking a little dirty in there. normally i just top 'er off with the green shit that looks like radioactive mountain dew, i don't add water either. if you know of a place that wont screw me over when i get it flushed, let me know
~justin
I had my system flushed and replaced coolant with Zerex G-05 (the yellow coolant recommended for Daimler Benz). After some research on BOBISTHEOILGUY.com, I was convinced it is the best coolant available today. I replaced the DEXCool fluid. I don't know any mechanics that have a good thing to say about DEXCool.
I also added a bottle of Hy-Per Lube Super Coolant. Test data shows it is superior to Redline Water Wetter as far as corrosion prevention is concerned.
http://www.hyperlube.com/HPC-100TESTRESULTS.doc
The G-05 has stayed very clean in the 10K since I flushed. As I expected, there is no difference in Operating Temperature, as it is regulated by the thermostat, but I believe corrosion protection is superior.
I feel the G-05 really is good for 100K miles so I wasn't interested in a "lifetime" coolant like Evans.
1 - 3 of 3 Posts
