1 - 10 of 10 Posts
i have replace the bpc and the waste gate now i only have low boost , before i had pulsing boost, so now im going back to the old parts and start again.
The bpc was blocked and the car was over boost and the waste gate rotten way and I set the ather just like the old one, it has a new turbo, 9000 aero
Discussion Starter · #4 ·
The things is that I replace the bpc and works fine it was slow at work so I have replace the waste gate
So the low boost started then and today I didn't drive my car I drove the wife today for oil change,
What do you consider "low boost"?
get a boost gauge on there - those dash gauges are never the most accurate. You are running a TD04 turbo on a 93+ 9000 I assume which HAD a T25 turbo? Was the software int he ECU updated with the turbo? Was the car originally a LPT car?
Do you have a boost gauge to tell us how much boost?
IE baseboost? or slighty more etc....
Discussion Starter · #9 ·
It doesn't feel like a base boost little more than base when I get home today ill put the boost gauge on it and see how much boost its running
1 - 10 of 10 Posts
