1 - 14 of 14 Posts
just put on my new Zimmerman crossdrilled rotors and EBC greenstuff pads for the front...(didnt have enough for the rear) need to brake them in more but so far so good!!
thanks to Erics helpful site and some beers!!
i will post pictures when i get home tonight!!
:D just wanted to boast :D
Nice, im also planning on doing this upgrade.
Were did you get your parts and how much did it cost you(If you don't mind me asking)?
Also would the stainless lines be any better then stock?
Thanks
Discussion Starter · #4 ·
i got the rotors from eeuroparts.com..cheapest i found, for about $120 and the pads i got for a present...they were off of ebay for about $80.. i plan on doing the rear sometime but the front i needed done anyways....
yes i want to get the s/s lines too, i heard they are good because they dont "flex" as the stock ones would under heavy breaking....so you dont get any sort of fluttering.......
yes, there's a huge difference between stock lines and ss lines....i changed from stock to ss lines on my motorcycle and it was like being in brake heaven.
I had heard that eEuroparts had had problems with the EBC pads on Zimmerman rotors and stopped selling the EBC's for that reason (and EBC's bad customer service as a result). I remember seeing a couple of threads on SaabNet (please don't ban me :( ) about this.
Trollerator
exactly what was the problem? brakes are something I don't wanna have problems with.
Trollerator
iwantaviggen said:
here are some pics....
http://memimage.cardomain.net/member_images/12/web/348000-[/quote]
I like the pink Barbie mechanic stool. :wink: :lol:
nice brake setup! 8) 8) 8)
Discussion Starter · #11 ·
hey what ever works!!
thanks....
Q-SAAB, the reason i got my set up was because i have heard only praise towards the set up...but time will tell....
Trollerator
thanks....
actually, you have given me a good idea. I might just stop at the next tag sale i see, and see if I can pick up a little plastic stool like that for a dollar or two, it would be perfect place to rest the caliper for brake jobs and if I can fit on it, :shock: a good place to sit when detailing the wheels.
so did you get drilled discs in back, too, or just fronts?
Trollerator
Q-SAAB said:
abducted - not real sure what the issue was, you might want to call eEuroparts and ask them, maybe also look up the threads on saabnet - their BBS software sucks ass so it's a bit cumbersome to find the threads you're looking for, but this should give you a start: http://www.saabnet.com/tsn/bb/NG900/index.html?bID=91265
interesting stuff... I really like the look of drilled discs, but maybe slotted are better to avoid situations like this, to clean off the excess pad material that might stick to the rotor?
There is quite a difference in opinion on which is really better, drilled or slotted. depends who you ask...
Ideally, I'd like to find some drilled AND slotted for both front and rear. Group 9 offers drilled and slotted Brembos, but someone on SC ordered drilled Brembos and got KVR rotors instead or something??? He wasn't too happy.
Anyone ever use these? are they any good? http://www.saabperformanceparts.com/item174.htm
1 - 14 of 14 Posts
