pull the half shaft carrier out also on the back of the block and it will slide right in if the engine is jacked up..... also take out the top motor mount to allow more movment
edit i see you did the top, you need to undo the rear engine mount and actually take the braket off the engine iirc... i may have done this once with out pulling the bracket off but i know i did it easyest with it off
