1 - 18 of 18 Posts
Depends on how hard you hit it. Plug is steel, but the oil sump is rather fragile cast aluminum :)
Use the breaker bar.. if you don't have a lot of experience with using a hammer on the plug.
Giving the plug a good thwack on the head with a deadblow hammer works. if all else fails, buy a new plug & get the old one out buy using a chisel & hammer on the edges to turn it.
next time just dont overtighten the plug or filter. If you have access to a lift it will be much easier to tend to.
1 - 18 of 18 Posts
