1 - 2 of 2 Posts
when i was changeing the oil in a 9000 earlier, the filter came off with a bolt on it, this car is tuned stage 3 so when i looked up i seen a circle object, then backed the bolt off, and reinstalled this circle thing, it had wires, and a relay running to, and from it, now the car massively leaks oil, is this part aftermarket, and could i by pass that and run the filter to the factory filter spot by removing this object.
get back at me guys
p.s. owner says its hooked to oil temp guage
1 - 2 of 2 Posts
