1 - 3 of 3 Posts
Hey gang,
1999 9-5 wagon /w 2.3 automatic
I've had my 9-5 wagon sitting for about 2-3 months, would start and move every week or so. Two weeks ago moved it into garage so I could put new brushes into the blower, job went great.
One week ago, we had -20c weather for 3-4 days. Tried to start car then, and it would not start.
I added 500ml methal hydrate and waited till the next morning - warmed to -5c and the car started after about 5-7 hard cranks. It sounded like a diesel starting up and catching on 1-2 cyl and then working it self to an idle.
Ran it for 3 minutes charging the battery and then shut it down.
Went to start again 3 days later, and she would not go. Same hard cranking, but not catching.
I put in 10l of fresh gas thinking gas might be very old. Car still no start.
Checked some vacum lines to throttle body and tightened connections.
Opened fuel pump hatch and pump can be heard humming on.
Tach jumps a bit when cranking.
Smell of gas around throttle body.
Pulled a code p1251
Any ideas?
Seems next step is to reset the throttle body.
Discussion Starter · #2 ·
Update:
-I reset throttle body, it was indeed triggered.
-Unplugged battery
-Took out spark plugs & noticed they were platinum or iridium. They were wet with gas.
-Swaped in old dirty bkp7r3s or whatever from other spare head & also spare COP.
- plugged in battery
- she fired right up.
- still have very loud annoying belt squealing noise. Have to fix that.
All this in -10c and snowing gently in my driveway.
My hyundai accent has never had these many issues.
Discussion Starter · #4 ·
the plugs will do that, get a new clean set of NGK BCPR6es plugs and only use the correct ones form now on...
Yeah, I am not convinced that the problem is solved for good, I wonder if this was a symptom of something else. eg. bad maf fouling the plugs
1 - 3 of 3 Posts
