1 - 17 of 17 Posts
Just swapped out this 6 puck clutch and Viggen pressure plate for a stock Viggen setup.
The action associated with this clutch was not condusive with my daily commute.
Has less then 150 miles on it.
Comes with new pressure plate screws.
Retail:
$165 for the clutch
$211 for the pressure plate
$33 for pressure plate screws(6 x $5.50)
Total: $409
Asking: $250 shipped OBO
Discussion Starter · #4 ·
Not so much the noise as the on/off engagement. Action was very positive.
I upgraded to a 9-3 trans, hydro clutch, aluminum flywheel and this clutch at the same time. Perhaps it was just more changes then my mind could handle. ;)
Discussion Starter · #7 ·
Yes, I'm sure the flywheel is part of the equation.
However, not having a holset is probably also part of it. ;)
Clutch parts
If you sell the pressure plate separate, I may be interested in the friction plate (disc/6 puck) and the bolts.
Shoot me a line.. maybe we can make a deal.. I also have a new Viggen disc in the box, if you need it.
[email protected]
Scott
1 - 17 of 17 Posts
