1 - 10 of 10 Posts
ok guys...need your help...
im trying to wire in the afc but looking at my trionic diagrams, i have no idea what will give me an rpm signal..Throttle Position Sensor? or do i have to find the wire straight to the tach?which of course i dont have...and what will gove me air flow pressure input/output? im so confused..
HELP ME OUT!!!
if your ecu looks like that, then it's probably T5 but not the same as mine, my car has T5 but the boost control, ignition and fuel are all in the same box, they are not separate like on that website
air flow pressure things? are you talking about the MAP sensor?
wow quazies site is very informative!! someone should post it in the links page...also does anyone know of an ECU pin coder for the 9-3se
saabkid37 said:
possibly got the info i need...ill let you know how it goes
glad to hear everything is going well
i have been looking for one for ages, please keep searching on your end, i'll continue looking....it is soo hard to find an ECU pinout for a 9-3
i have a 99 9-3 base model (185bhp) which is T-5 unlike yours, o well if i find anything i'll let you know
1 - 10 of 10 Posts
