1 - 5 of 5 Posts
Just recently installed a Viggen Intercooler on my 1999 9-3 T5. However, the idle was blipping from about 1200 rpm to 2000 rpm and my check engine light came on right afterward. The idle has stabilized, but CEL is still on.
Any thoughts???
HNNLIC
I've never heard of this problem, but try resetting your ECU. It may just be that the addition of the VIC threw off the ECU. Just disconnect the negative battery cable for 10-15 minutes, and make sure you have your Radio code ;)
Anyone have any other ideas about this?
make shure you double check all the hoses and anything that could have come loose wile intalling the VIC....and reset the ECU...
You should reset the ECU and do a series of adaptation runs (3rd gear pulls from 1500rpm at WOT) after any engine mod. The ECU will adjust to the new engine parameters.
1 - 5 of 5 Posts
