I am putting a 9000 Aero TD04-15G#6 which has been upgraded to an 18T on my 9-3.
I have been doing a lot of searching for the specifics on the swap, running into the possible issues of:
I am looking for the right wastegate actuator/arm/bracket. I have found plenty of information saying that the wastegate actuator arm needs to be curved, and the wastegate bracket needs to be fabricated or modified. If anyone who has done this swap can share their solutions I would appreciate it.
The intake inlet is a tight fit- is there a specific 90° bend that is a known fit, once the turbo shows up I'll check the bends that I already have- this might not be an issue at all.
I have a couple ideas for the crank case vent, including a 1/2" outlet on the intake for a 1/2" i.d. hose run from the nipple on the crankcase.
The oil return needs to be specific to the TD04.. I have this lined up from eeuro and should not be an issue. Of course the new gasket is included.
I am doing braided stainless steel coolant lines. problem solved. I have heard the 15g has the coolant ports on the top and oil on the bottom, rather than the 15t which are opposite of each other. (or something like that- basically they're different from the 15t) this shouldnt be an issue, just a matter of clocking correctly to make sure the oil drains free.
- wastegate
- intake inlet
- crank case vent
- oil return
- coolant lines
