MegaSquirt purchase
2.2K views 29 replies 11 participants last post by  DeLorean
i am filling my online shopping carts and am ready to place an order to MegaSquirt. PaulH had put together a list with links in the 'MS oh so very daunting' thread, and i am using that for guidelines.
i see mention of using a 9000 intake temp sensor, but am thinking to just purchase one from diyautotune.
there are several listed on this page - http://www.diyautotune.com/catalog/sensors-c-36.html
there is a port on the top of the 2.0 throttle bodies, but i dont know if there is something similar on the 2.1 TB's... something i still need to purchase. if not, there is another port on the underside of the intake manifold, which could be used, but i dont really feel like pulling my intake off (again, so soon) to drill and tap it.
i have the 4 bar MAP sensor, the unassembled MS1 kit (what are you guys running? i would love to be able to start with a file that someone is running now and tune from there rather than starting with a blank slate, should i go for the MS2 kit?),
the parts i have in cart are the ones PaulH listed -
http://www.diyautotune.com/catalog/megasquirti-programmable-system-pcb22-unassembled-p-28.html
unassembled megasquirt v2.2, defintely the cheapest way to go, especially if you can solder compitently. you could also get the assembled one too, either way you want to upgrade to at least the 3bar map sensor...im wishing i had gotten the 4bar at this point. (thats 4 bar absolute, so the 3 bar is "only" good to about 30psi on the gauge) theres also a couple little tweaks that are detailed on keiths site that need to be done for our application.
actually now that i look at the site, this is the way to go for the map sensor:
http://www.diyautotune.com/catalog/mapdaddy-sensor-with-barometric-correction-p-117.html
need a DB-37 connector, female, solder cup, like this one for $4
http://www.surplussales.com/ComputerAccess/DBConn-4.html
one of these for use with the db37
http://www.diyautotune.com/catalog/metal-db37-cover-with-hardware-gaskets-p-127.html
then for a c900 you'll need a throttle body from a 2.1l car, an air temp sensor from a 9000, and if you want to run DI a crank sensor from a 2.1l car.
that should about do it...dont think i missed anything important
Paul
will i need an adapter of sorts to make the wideband O2 sensor i ordered from GS work with LH, or easily plug into MS? i want to get this wideband in ASAP.
http://www.genuinesaab.com/catalog/product_info.php?cPath=42&products_id=526
i think i have everything together that i need... but am not sure and hate waiting for snail mail to get stuff to me
yeah thats about it, i wouldnt bother with the GM temp sensor that DIY sells, the little sensor thing is going to fall off and get sucked into the engine, its not designed to be in boost environments. 9k sensors are the way to go. also you are going to want to install it in the intercooler pipe right before the TB, if you install it on the TB or in the manifold you will have hot start problems due to heat soaking from the engine.
Paul
awesome. excellent information, i had not thought about having to isolate the temp sensor.
wtb - 2.1 throttle body, 9k intake air temp sensor
and what about the Stimulator?
i've always wanted one, just because of it's name...
after reading more about it, it looks like a great diagnostic tool, i will be purchasing and assembling the Stimulator as well
not to discourage you but the connector in the 2.4 ecu board is much more difficult to separate than on 2.2 ecu's which is why paul is not making an adapter for them now. However if thats a spare ecu then by all means start ripping that thing apart, because it really does suck trying to solder a wiring harness in the footwell.
ya know, if you buy an unassembled kit and a stimulator, you're only like $40 away from just buying the assembled box. i don't know about you guys, but $40 is well worth it to not have to:
a) spend all the time to assemble the ecu
b) worry about one more thing on the list of things that could have been done wrong
i know it's probably a good educational experience to assemble the kit, but when i order mine, i'm going with the assembled kit.
i'll just use red bull as a stimulator.
good advice, I built the stimulator and the unassembled box and had a good time building them but if I had to do it all again I would just buy the assembled one. However the price has gone up across the board because the kits are now using better processors so it is a little more $$.
on an LH 2.4 or 2.4.2 car, at the moment the simplest approach is going to be to hack the connector off the harness and wire the DB37 directly do that. unfortunately this will also make it so the LH system can't ever be used as a back up.
we were looking at some custom bits the other day which might help us make an adapter for 2.4 cars, but at the moment making a reliable adapter that I would consider automotive grade is still a little bit off...
my box is open, and i am starting to see what you guys are talking about. i have the cover off and can see why one would not want to start making adapters for others to use.
i am sure that i can come up with something that i would be comfortable installing and reasonably sure it would hold up to the vibration and possible occasional bump from items in car, but i do not see it being a quick and easy job, or something that i would want to replicate.
Heh, this thread reminded me to get off my ass and sort the IAT for my MS fuelling. Found a 9k IAT on ebay, 7 pounds 50p, 15 dollars in your money.
I also need to make up an ecu connector for clean install, but unfortunately mine has the rarer lucas ecu. wierd 37 pin connector. Not had any luck yet sourcing broken ecu's, and I aint tearing apart my perfectly working ecu. Surely you guys must be able to source broken bosch ecu's from scrapyards, they were used on more than just saabs?
if you were to tear yours apart, there would be little point to using it as an adapter. the reason i want to make an adapter is so that i can plug the Bosch ECU back in if need be.
sadly, there is nothing wrong with the one that i am tearing apart. well, nothing beyond the fact that it has a stock fuel chip :rolleyes:
i know nothing about the Lucas system other than that it is not available here in the US and i will probably never see one in person. i am guessing that they use an entirely different plug from Bosch LH 2.2 and 2.4
#27 ·
the TB itself is different and they won't accept the correct TPS. You can make an adapter to make the correct TPS fit on a 2.2/2.4 throttle body, but even still the new position of the TPS (basically sideways) interfears with the IAC valve pipe. Also, the LH 2.4 cars (89-93 900-turbo) also do not have the correct TPS either. It must be from an LH 2.4.2 car. These are the 91-93 900 2.1 liter cars.
#30 ·
not me, but it should work. There is an extra line that will probably need to be plugged, and I think a plug that will need to be popped out and a a line out in, but as far as I can tell that should work fine. non turbo 9000's 90-94 should all be LH 2.4.2 These TB's really should be pretty easy to find. Like I mentioned elsewhere, I'd sell em to people for $40 + shipping.
