1 - 9 of 9 Posts
Discussion Starter · #6 ·
this isn't really what I asked.
I Didn't ask "do I need this?"
I simply asked if anyone knew anythig about it.
is it plug n' play? do I need to convert to s/s lines?
is it spaced so I can use taller injectors without spacers?
Seems counter productive. Run new lines and mod the pump housing filter etc only to run 750cc injectors without spacers. The ID1000s fit no spacers. Now to run larger lines/ second is starting to be necessary with the 1k injectors... A good idea is a metal pump housing so there is no need to run a AN bulkhead fitting through the stock plastic pump cover. That makes sense in a crash.
1 - 9 of 9 Posts
