1 - 4 of 4 Posts
When changing vacuum hoses I broke the plastic nipple that the crank case ventilation hose connect to.. I purchased a new nipple from Saab dealer. My question is where does the other end of the vacuum hose connect to?
:x :x :x
Don't forget there is a check valve :!: in the hose between the nipple on the crankcase vent and the throttle body. The function of the check valve is to prevent positive pressure (during on-boost conditions) from getting into the crankcase and blowing all the oil out of the filler neck... :shock:
1 - 4 of 4 Posts
