1 - 3 of 3 Posts
When I install springs in my 2003 Aero, I am going to be left with neg. camber. In searching I have read about shimming the hubs to compensate but which bolt do I shim? Does this apply to the front and rear or only the rear? I also read the front camber is not affected. From the diagram, it looks as if the lower damper retaining bolt would be the one for the rears.
Front Camber can be easily adjusted and yes it is the lower bolt on the rear. Are you sure your camber is going to be out. Mine was fine when I put lowering springs on.. :)
Front camber is ok but rear is out a bit more than stock (they are sending these out of the factory with neg. rear camber for some reason. It's not too bad though and I have had the car lowered for about a year now without any shimming.
1 - 3 of 3 Posts
