I am driving a '92 base c900 hatch, 5-speed, to Detroit this weekend for another list member.
The car seems like it has a miss when hitting the gas pedal, and then it catches at about 2k rpm and then zooms quite well up the tach gauge.
The car has had a recent tuneup, cap and rotor (which got rid of some other miss issues), so the usual suspects do not apply.
This miss is also not 100% - it happens maybe a third of the time. It's also easy enough to work around - just get the revs above 2k.
The car does have a bad front motor mount.
Question -- could the bad motor mount be causing this problem somehow? If the engine were shifting, could it cause the ignition system to miss or dial back too hard?
