1 - 9 of 9 Posts
SID shows a low coolant message upon start up.
Changed the black sensor in coolant reservoir - still have low coolant on SID - yes I have checked to make sure enough coolant.
Could the SID be from another car - and showing previous errors?
What is resistance supposed to be for this sensor in overflow tank? Could not find in the WIS
Discussion Starter · #2 ·
EDIT - found it in the WIS under SID, not cooling system:
"If circuit to the coolant level sensor is borke, text message "fill coolant" will be shown despite correct level.
If a short-circuit to gorund occurs, the check message will not be shown even if the coolant level is low.
Discussion Starter · #5 ·
I haven't but wonder if previous owner did? Could that cause the issue? With the car on, what voltage should I have on the pins for the wiring harness to the sensor?
I believe changing SID's from a different model year will trigger the fill windshield fluid message, not fill coolant.
There might be a bad ground involved.
It's more of an expansion tank in that it is part of the pressurized system.
This coolant level design is sometimes problematic. I had a GM car (same design) with the same spurious false warnings, usually when cold. When the engine was hot, the increase in level would cure the "problem". Bad design. Try a higher coolant level, just not too high.
Good Luck.
1 - 9 of 9 Posts
