1 - 11 of 11 Posts
My engine block looks like it's leaking oil (or some liquid) from a hole (not sure what it's used for). Maybe it's my valve cover gasket or something around there? If you're looking at it from the front, it's on the right side next to exhaust manifold, on the side of the engine block. I dunno what it is. i'll post pics later
spray the engine down with degreaser, clean it and then run it a few days until you see where its leaking from ;)
It is probably coming from the distributor plug cover( that's notorious for leaking) and or from the valve cover gasket
i was going to say that earlier but didn't it's the first thing that is generally suggested in these cases ;)
Check and see if its the steel lines that run under the exhaust header from the water pump to your heater core lines. sometimes they rot and start leaking.
1 - 11 of 11 Posts
