just found this on the forum.
http://www.saablink.net/forum/showthread.php?t=40783&highlight=flickering+oil+light
I just put 5-30 in it so the oil flickering might be solved...
What do you guys suggest I use in the 90+ heat of florida? Should I completely change the oil again or can I mix in a heavy oil or an additive to save the hassle of changing it after less than 50 miles on the oil change? Would you drive it like this?
I'm thinking lucas heavy duty oil stabilizer will do the trick... Let me know what you think.
Thx
Thx
