If you get that message, you can try pressing the unlock key on your keyfob and the car should then let you use the key to start it.
It may be as simple as the key antenna was ruined by all the water or maybe just some moisture left in the electrical connector. I would take it apart (it's in the piece that surrounds the ignition cylinder...at least on 9-3s) and make sure it is nice and dry.
Otherwise you may need someone with a Tech II to take a look at it.
