1 - 12 of 12 Posts
HNNLIC
Quicktime is required:
This is from outside the car in the back. Inside is ALOT quieter, otherwise he said he would've removed it.
http://130.235.150.5/~bollman/saabljud.mp4
Also an in-car video:
http://130.235.150.5/~bollman/70130.mp4
The exhaust is the JT 3" full exhaust (turbo back) w/ Sports Cat and the 2 muffler setup. Its on Bollman's 1999 9-3 SE 2.0L Turbo w/ a Stage 1 BSR ECU...which he plans to upgrade to a Maptun Stage 3.
HNNLIC
No he did it with an MD recorder and a cheap mic.
Yea im sure yours sounds deeper, but ur exhaust is universal aftermarket.
it wont let me listen to the clips....i tried opening it from the site and saving it to my comp. but it still didnt work...man that sucks
HNNLIC
Discussion Starter · #6 ·
They require Quicktime.
i have quicktime, but they wont work on mine, but then again, this lump of shit i call a computer is just that, a lump of shit, that doesnt work
Administrator
You´ll need a fairly new QT, like, 6 or newer. It´s MPEG4.
I put the mic under the rear hatch. The drains for water is quite big and would house the mic, the wire going inside over the rubber. I hope you understand, these parts of a car is not exactly in the vocabulary you learn in school... :D
I recorded it on a MD (easier, since it has auto recording level and is a bit small than a laptop, and also have a better battery lifetime ;))
I haven´t done any "post-processing" on the file. I could give it some more bass, since the mic probably has poor response in the low register.
I was planning to put one mic under the hood the next time also, to get the BOV-sound. But this will require me to get a mixer into the car, but it _will_ be done :) Also, I will optimize the placing of the rear mic, to get better sound, and to get rid of the wind shear.
The speedo was recorded with my celly, a SonyEricsson P900, it records directly to MPEG4.
You notice it sounds similar to a Subaru boxer engine? Cool! So will it sound similar, if not, deeper on a 9-5 aero? 8)
1 - 12 of 12 Posts
