1 - 8 of 8 Posts
Looks like the radio coax cable that goes back to the antenna. You maybe able to get another coax connector and resplice it. You could also get a 15-20 ft standard radio antenna from amazon or car audio store and run it from the antenna in the trunk thru back seat under carpet behind dash and up to radio.
Discussion Starter · #4 ·
Thanks for the info. I wasn't sure if I needed a SAAB specific coaxial cable.
i cut the only one at the junkyard because I though I would be able to splice but it has small wires that are insulated then small copper wires around that insulation.
I'll try Amazon or local Audio store. thanks
I kind of feel like the stock antenna is spliced from the factory by the console. But I don't remember.
If someone has access to EPC they could look.
1 - 8 of 8 Posts
