I think you should go with the spec stage 3, then get a lightened flywheel. Promptly after, let me know how drivability is that way i know whether or not to buy a flywheel for my car
Anytime you come down, please let me know and we will definitely meet up. Conversely, I might be interning up in Olympia later in the summer but I will keep you posted on that.Come on out, you're welcome anytime. I'll be in socal this summer, maybe you can show me your Z.
I'm in too.Anytime you come down, please let me know and we will definitely meet up.
Burfoot County Park FTW.Conversely, I might be interning up in Olympia later in the summer but I will keep you posted on that.
Hmmph. Too easy....I'll be in socal this summer, maybe you can show me your Z.
Says the guy who shows pics of it to his dad.Hmmph. Too easy.
Hahaha.Says the guy who shows pics of it to his dad.
I think you should get a CAD diagram for a new CNC gearbox casing.
Future/wish list:
-New turbo? GT30 or 35R?
-Scanwest cryo-treated & shot-peened transmission in chillcast case
Wow, that right there is impressive. Be proud of that one.I think you should get a CAD diagram for a new CNC gearbox casing.
And while your at it, have it made for a new strong gear set :wink:
I just snapped my primary chains with my GT30busted through the casing as well.
Thanks for the kind words. As for the decor panel, yes it is original, it is not modified. And it's one of the only one I've ever seen, picture or in person.Hi there,
Just curious, amongst all the other things on the hottest vert on web, a question about your decor panel. This car intrigues me, no end! So many questions and so few avail web pages!
Was it a specific convertible decor panel or did you mod a decor panel from the hardtop 900? Way back into the pics on the "other" site i cannot ever remember you saying that modded the panel? If not modded does that mean you have the one of two ever to come out of that italian factory? The other must have been used in the catalogue...
TIA
I am definitely not happy with where it sits now. Needs to be lower all around, and adjustable.Any future plans for suspension? I know in the past you have expressed want to go lower, but do you think anything is gonna come out of this or are you happy with where it sits now?
You could put coil overs on it....I am definitely not happy with where it sits now. Needs to be lower all around, and adjustable.
Well, no one sells a coilover setup so that's all custom. One idea is to forget about the spring perches altogether and just run a short coilover off the shock mount, but I am not convinced that there is enough bracing around the shock mounts to handle the added stress. It was never meant to hold up the entire car from those mounting points.You could put coil overs on it....![]()
it would require quite a bit of fab just talk to Luke at Saabrally.com he's got front and rear coiloversWell, no one sells a coilover setup so that's all custom. One idea is to forget about the spring perches altogether and just run a short coilover off the shock mount, but I am not convinced that there is enough bracing around the shock mounts to handle the added stress. It was never meant to hold up the entire car from those mounting points..
Pics of your old slammed 4 door are required.it would require quite a bit of fab just talk to Luke at Saabrally.com he's got front and rear coilovers
