There, there. *pats Palmy on the head*
It's just jellus of the Miata. You should sell the Miata.
Wait wait wait let me get my c900 in there first.
If the dash lights came on, I'd assume the ignition switch is fine.Have you checked the starter or ignition switch? I have an extra of each if ya need 'em.
"C900"?My 86 is being a world-class C***. Yes, that's a capital C.
I know the feeling. I've been driving my 900 and there is a drain on the battery somewhere. If I drive it daily it's fine because the alternator charges it back up, but if I leave it for a few days it's dead. Erk. Hope you fix your issue before giving up and selling it to Saabeh.Anyway, the issue.
I drove it to work today. Worked great. Park it in the driveway.
I come home a few minutes ago, and I need to move it to get a car out of the garage. Put the key in, turn it. The dash lights up and the digital voltage gauge I have reads 12v. Turn the key. Everything goes dead.
Hmm, it usually starts when it says 12v. In fact, it always starts when it says 12.
Check the battery with a voltmeter. 13.6v.
Grounds all attached, new battery cables, good connections.
Dead. Totally dead.
I only want to buy it so I can race ViggenLuca. I need to learn how to push the limits beyond my limits.Hope you fix your issue before giving up and selling it to Saabeh.
:lol::lol::lol:"C900"?
Mine's doing the same thing. I keep a jump box in the trunk though, and park on hills whenever possible.I know the feeling. I've been driving my 900 and there is a drain on the battery somewhere. If I drive it daily it's fine because the alternator charges it back up, but if I leave it for a few days it's dead. Erk. Hope you fix your issue before giving up and selling it to Saabeh.
A battery draw should not he hard to find. Hook up an amp meter between the battery + & the + cable. Keep the car "off" and if you have a draw, you will see amperage bleeding through. Start pulling fuses, and you will eventually find the one that it is when you see 0.00 on the multi meter. What ever it is, you will know what it is then. At that point, remove or replace the device that is sucking the power when the car is off.Mine's doing the same thing. I keep a jump box in the trunk though, and park on hills whenever possible.
