1 - 17 of 17 Posts
I may have a place in doors at my nearby other work to work on this car. The door seems 5.5 feet wide. But outside there may be a staircase in the way.
Also I can snag an 85ish N.A. 8 Valve head, will this work on the 78 B motor turbo?
I also plan on snagging the spindles and calipers from it, these bolt right up without much hassle?
It's as wide as a 900, I don't know how wide that is. Wider than a 96, narrower than a 9000. :)
An 8-valve H-motor head would not work without a lot of modification and I don't think there would be much benefit to it. There's a guy who put a 16-valve H-motor head on a B-motor block in his really nice red 99 sedan and it took quite a bit of modification, I remember seeing it at SOC10. You'd be better off going with either a complete H- or B- motor. Keep in mind that if you do the H-motor you'll need to put a dimple in the firewall to accommodate the water pump pulley.
Also, yes, '87 and early 900 front spindles and brakes will bolt right on. This is a good modification as it makes the front rotors on a 99 much easier to change. This is one of the first mods I did to my long departed '76 99 EMS that I drove in college.
Years back when I had my 99 Turbo I liked using the very early B engine head. They seemed less prone to cracking. The easy way to tell them was that the exhaust studs/bolts used a 17 mm socket instead of the more common 13mm socket.
Discussion Starter · #6 ·
Ok, so no on the head, I will hope nothing is tragically wrong with the one it's got.
I will definately grab the spindles and clippers off the 85 sitting at the Mt. Airy yard.
I MAY have a one of a kind 99 brake setup for sale if I upgrade them to the proper ones the car was intended to have... gives you later 9000 front brakes :)
You should shoot for vented front rotors, the hubs are specific, should be all 86 turbos, and 87 turbos and S models. You should hold off and go to new ringgold with us, there are at least 4 of those cars there with good hubs, and that place is gonna be way cheaper than crazy ray's.
Paul
Yea just measured the second garage bay, just under 8ft wide with enough room for C900, hopefully will have enough room so that I won't have to do the Dukes of Hazzard :winky:
Discussion Starter · #15 ·
According to thesaabsite, the exhaust valves are the same all the way up to 88. It's the intake valves that are NLA and car specific. But I don't yet know that I need them. Have to get the head off the car and take it to my machine shop.
As for New Ringold, I may head up in 2 weekends. I'm working my days off this week so that I can finally have kiss my ass money.
Yea going to pick up a head at Fairfax, they wanted too much money to replace 4 exhaust valves on an 88. :icon_frown:
1 - 17 of 17 Posts
