Well, first thing you do is turn the car on and physically look and listen to the BOV. Listen for any high pitched sounds that indication the piston is not sealing properly and therefore leaking air. Second thing is to use the cable near the throttle body to rev the car a bit or have someone rev it while watching the BOV. You should see the BOV piston moving up and down as it moves down to close off the BOV to retain boost or if it moves up once the throttle is released to let the car release any boost and to allow the car to idle properly.
The BOV diaphram should immediately respond to throttle input. If it looks like it is reacting slowly or not at all, then you have an issue with the BOV.
