hesitation and 'fitting'
1388 Views 1 Reply 2 Participants Last post by  J300
Hello forum!
Some weeks ago my car started to drive weird.
It used to hesitate and throw the odd 'fit' whilst accelerating, particularly around the 2000RPM as I went through the gears. Its kind of like turning the ignition on and off whilst driving, the effect is how I would describe hesitation and fitting, like a violent cough. Sat in the seat driving - you can pretty well feel the engine block "coughing".
Its getting worse. Now it does it when I'm cruising in 4th and a little in 5th.
I'm no mechanic but searching google I managed to remove and clean the EGR. No effect. It wasnt that bad anyway.
Any ideas where I can start working this problem out to a resolution. Please bear in mind I'm no mechanic so looking ideally for guidance and support rather than "its the injector" or something like that - which wouldnt really be a great deal of help to me I'm afraid.
Thanks?
(How do I show my signature ??? which I set as "Saab 9-3 1.9 TiD March 2005")
1 - 2 of 2 Posts
Did you figure it out? start with new spark plugs and then have your ignition coils tested. probably a bad coil as they are individually positioned above each spark plug.
1 - 2 of 2 Posts
