1 - 8 of 8 Posts
Discussion Starter · #4 ·
yes i have the proper hoses i had the viggen ic on the car before . and ets am guessing is the new one i order it from gs recently .
so far i remove the the bolts holding the ac condenser and oil cooler but i cant connect the hoses and is the oil cooler suppose to leave loose like that
Pictures will help, but I even had the original design and mine fit almost fine the changes were made to make it fit better. You have it going in the right way? You might have to reverse it, there is a wrong and right way to put it in.
1 - 8 of 8 Posts
