While running errands today, I noticed a small squeaking sound. Thought I would check it out when I get home as everything seemed to be working well otherwise. On the way home at the end of the evening I heard a *thump* then a vibrational noise that seemed to correspond to throttle input. Yet acceleration was very lacking. I figured I had blown off a pressure or vac hose causing some sort of issue. I was about 10min from home on a cool night so I decided to baby it home.
Once home I got under the car and found this:
The vibration is from the oilpan resting on the subframe:
The transmission mount, purchased at the same time seems to be fine. Other than being shifted due to the other mount failure.
As you can tell both mounts are in quite good condition, this is because I have only put about 35,000mi on these mounts. I have been so pleased with the poly mounts I was planning on purchasing a rear diesel mount to compliment them. I plan on replacing the broken engine mount with another poly mount as well as a diesel engine mount. I have emailed Nick regarding this to see what he suggests. I have been very happy with all the GS products and I continue to recommend them to everyone. This appears to be an isolated issue with the polyurethane in this mount as everything else about the mount has held-up as you can see. I figured I would just make others aware and share the little adventure I had this evening.
