1 - 4 of 4 Posts
My indy asked for my help find an aftermarket product to help front end Alignment on an 06 9-5. He states the the customers front end is -2.0
Found these from GS is this for both side or one side only? My qestion; what else can be done to realign the camber on the front end?
How the hell did the front become -2 degrees camber? There has to be some sort of suspension problem if it's that bad. Those adjustment bolts are mainly used for adjusting the camber to differ from the stock specs, so it is weird that you need them to fix it.
1 - 4 of 4 Posts
