Gear Box Malfunction on SID
1357 Views 2 Replies 3 Participants Last post by  DrewP
just got message Gear Box Malfunction! I just had a new transmission installed last September. What does this mean? 2003 9-3. Thank you
1 - 3 of 3 Posts
Could be a bad input sensor - get the code pulled and see if it's indeed that. Shouldn't be the trans.... How was the trans cooler/radiator when you replaced the trans? Should replace the radiator with the trans since those leak just as often as the trannies would fail - hope for sensor problem.
Could be hundreds of things, no use guessing until you get the code read.
Best,
Drew
1 - 3 of 3 Posts
