1 - 5 of 5 Posts
Ok, this has been happening since we got the car 6-8 years ago. When you go to fill up the car with gas, @ a gas station, It will click off like the tank is full if you pull the lever too hard and too much fuel comes out of the nozzel. Is it the shut off valve or something. We can never tell if it's totally full. We actually have to listen for the gas filling up inside the tank. And it takes like 15 minutes to fill up the car. Is this a common problem? And is it expensive to fix? Thanks
I'm not sure but it sounds like your filler neck might be some what blocked or the tank. I would drop the tank and pull the filler neck and see. thats all I got maybe someone knows different good luck.
Both my classics do this, but i've found if i turn the nozzle 90 degrees to the side it works fine for me.
1 - 5 of 5 Posts
