Can't tell you the pressures off the top of my head, but brass barbs will do the job nicely
the line is plastic so it doesn't stretch; are you suggesting this from experience or theory?Can't tell you the pressures off the top of my head, but brass barbs will do the job nicely
good to hear; thanks!Done this many times. Same concept as replacing a check valve on a Walbro fuel pump. I usually attach a brake line flaring tool to the plastic line so you get a good grip. Leave about an inch of space from the cut, do not use heat or you lose rigidity in the line. Spray some lube on the barb, grab it with some vise grips, apply steady pressure and twist back and forth a little at the same time. Works every time, never had a splice fail, even on pressure lines.
