1 - 14 of 14 Posts
Where is the test point on the fuel rail to hook up a guage (actual location)?
I have a 97 900S 2.3L
There should be a shreader valve in the center of the fuel rail. It may be covered by a black cap.
? Why would you be putting a vacuum on that. It should be pressurized, and gas will shoot out if you open it up.
Discussion Starter · #5 ·
oops. too quick too type. i meant i have a shock pump for a full suspension mountain bike that threads onto a shraeder valve. do you think that will work?
No. I wouldn't.
If you had just a gauge maybe, but not a bike pump gauge.
Discussion Starter · #8 · (Edited)
i can't seem to find the shraeder valve on 97 900S's fuel rail.
I removed the fuel pressure regulator, at the end of the rail and fuel came out. is that suffice for checking if there's fuel in the rail?
Those pumps would fall apart if you hooked up one to a fuel line. Rubber internals wouldn't like it.
I believe the schrader valve is only present on 9-3's with T7 engine management. For T5, Saab sells a tool that goes in between the fuel rail and fuel line. I'm sure you could make something also.
You could make something. It would be a bit pricey though.
Probably around $60 by the time all is said and done. You need a 5/16" female and male quick disconnects with a gauge adapter to go in between them.
I was thinking cut the plastic lines and make a tee out of some brass nipples.
Yea I guess there is that route too, but that could get messy. If not done properly it could lead to more expensive repairs.
1 - 14 of 14 Posts
