1 - 5 of 5 Posts
I've tried searching but can't find anything that relates to my issue, so here it is.
Basically my fog lights will work for a while with new bulbs and then 1 month or so later the drivers side will go out. Thinking its a burnt bulb i'll replace them, but comparing the driver side and passenger side shows no difference so i put the passenger side bulb in the drivers side housing(known working bulb) and it wont work. but a brand new set of bulbs will work for about a month or so and again the drivers side will go out but not burn out, just go out.
Sometimes if i leave it long enough(about 2 or 3 weeks) it will come back on.
I've replaced all known fuses with brand new and nothing changes.
Again this is only confined to the drivers side fog light.
Any one have this issue? or have any information?
Thanks
Sorry forgot to add that I did change all known relays aswell with no difference.
Are the housings all corroded? The bulb might not be getting a good ground on that one side. Take a good look at where the bulb sits in the lamp housing.
1 - 5 of 5 Posts
