Have you checked the fuel pump?
x2!?How can you have a '96 throttle body on it when it's a TCS car?
The tcs ecu needs to be calibrated to the throttle body you put on so that the ecu knows exactly when the tb closed. Without doing that the throttle body will get burned out and dieOK. Thanks. What happens if it's not calibrated? At the moment it seems to be running fine. Peharps it's a 94-95 tb?
