ebrake help
797 Views 3 Replies 2 Participants Last post by  Makeyousaab
I'm replacing my ebrake shoes and I'm having some trouble getting them in place correctly. I've managed to get everything together, but when I put the rotor back on the shoes are rubbing on the inside. the adjustment screw is as small as it will go, so maybe I put the shoes on incorrectly? Any help is greatly appreciated.
Thanks in advance!
1 - 4 of 4 Posts
You sure the adj screw isnt as wide as it will go? Is you e-brake "on" inside the car?
the adjustment screw is a short as it can get and the ebrake is off in the car.... I think I had not centered the pads correctly on the hub. It's such a pain in the ass and I don't think it should be this difficult.
so what does it mean when the ebrake only works when you spin the wheel clockwise, but going counterclockwise the handrake doesnt engage?
1 - 4 of 4 Posts
