1 - 4 of 4 Posts
My girlfriend's driver side seat heater will not turn off, even with the switch in the off position. :shock:
I told her to keep the ventilated seat option on to make sure the seat stays cool.
Any ideas on how to fix this or what might be causing the problem.
Help! :shock:
Super Moderator
Pull the switch and unplug it until you can figure it out. It's probably the switch anyways.
Thanks...will do...
I'm going to use the passenger side switch to check if the driver's side is faulty...it just dawned on me that i can test with the passenger's side switch...if it turns off with the other switch, then it's only a $65 fix for a new switch.
1 - 4 of 4 Posts
