Just make your own from regular steel of appropriate thickness to hold shape. They don't even have to look like that. just cut a fat cross-like figure, punch a hole in the middle, leave two sides as is, and bent the other two 90 degrees inwards to fit into the door hole, also bent them wavy similar to the original part so that they grab onto the door hole when the screw goes in. Better then OEM
