1 - 5 of 5 Posts
Looking to debadge my 9-3 and put a new emblem on the trunk. Any suggestions on the best way to do it? Also, I'm under the impression there are molding holes in the trunk, how can I keep from scratching it when removing the emblem?
Thanks
L
Premium Member
Heat with a hair dryer, separate with dental floss, use Goo Gone on the remaining adhesive.
This is the perfect method to remove the SAAB and 9-3 lettering.
To remove the emblem:
Take a flat-head screw driver and a rag. Tuck the rag under the wedge of the screwdriver and slowly pry up, going in a circle around the emblem untill it is fully pryed out. Clean the dirt out and push in new badge. Its a simple yet tedious process.
Discussion Starter · #4 ·
Thanks guys. Do you know if a 05 emblem would fit on a 06? I was not talking about doing the 9-3 or 2.0T emblems, but the actual middle trunk emblem itself. Still the same processes?
Yup.
1 - 5 of 5 Posts
