1 - 20 of 35 Posts
When i'm going to upgrade the my IC, i was thiking about going with Maptun. But then talked to Blaque_Out and he said custon with Spearco. Well i was looking at garaget.org and some awesome saabs there. I noticed some nice intercoolers. I'm looking for some like this, i want a nice tall one that will sit low also so it will look good when the new bodykits come in. Anybody boby have any input>?
And just think, I started the whole no front bumper fad years ago. :p
Seriosly, I am thinking of having a custom spearco done up. Not for a while though. I wanna see if i can blow up my Viggen intercooler first. 8)
Discussion Starter · #5 ·
You know any intercooler that will be as big as thoes> Looking for a nice tall one.
I found this one, but It looks like it has plastic end tanks. 95 Aero. In the performance section on EEuroparts.com Cheap too. $119
9k incercoolers are HUUUUUUGE - they're not incredibly thick, but I they're probably bigger than the radiator on a NG900/GM9-3.
Honestly, the Viggen piece is the best deal for your money IMHO. It's fairly big, but not huge enough to be a pain to fit. Anything much bigger will probably require sxome custom fitting, removing the A/C, etc. Plus, you can convert your stock counterflow 9-3 intercooler to a Viggen setup for less than the core would cost ro do a custom spearco setup. And then you'd still have to pay someone to fab the end tanks and tubing. All for something that might be an inch or two bigger than the Viggen piece.
Problem is, soon I will be seeing boost levels that would require an all metal unit. I will try with the plastic on the VIC, but worry a bit.
Discussion Starter · #9 ·
I think you might be going a little overboard with the difficulties on installing a custom IC. I don't think it’s that hard, and the company that you buy it from supplies hoses for you so problem solved.
The Viggen IC is too small, when shown on a car with a Viggen bumper, it looks like shit, and it does not even fill in the whole hole. Just imagine how ugly it will look with the new body kits coming out. I want that space to be filled. For custom IC it’s about the same price to, so for a little extra time for fitting, and for a bigger IC (which I’m sure will fit without removing anything) is well worth it.
Hey Tweek , I just remembered a stock Volvo intercooler is similar to a 9000 unit but has inlet and outlet like a ng900 unit . And there cheap too.
Oi.....the intercooler dilemma...This is what has been keeping me up at night. I'm trying to decide what's best to put on the car to eventually handle 300 bhp.
Tweek, Snow, you'll definitely want to stay away from a 9000 IC unless you don't have air conditioning or live in Alaska and don't need it! You'd need to remove the AC to fit anything bigger than 9 inches, and even that's a tight fit that would probably require re-routing one of the oil-cooler tubes. The stock 900NG IC sits right on top of one of those tubes. It's about 7.75 inches from the top of the oil-cooler tube to the bottom of the AC component. This is a very important measurement, as this will dictate the IC depth if the oil cooler tubes aren't re-routed, and not the eventual location of a body kit.
Snow, that's actually a Spearco on that Viggen, not the Viggen IC. I hear ya, tho: It looks kind of funny from that angle, but there's really not much that can be done. A tall narrow IC might just work, especially if you put the collection tanks at the top and bottom. Shorter tubes mean less pressure loss...but most of the IC will be hidden behind the mass of the bumper. There's a guy from Finland or Sweden on SaabCentral who did just that.
It doesn't help that the 9000 IC is also pretty restrictive and not very efficient, with lots of pressure loss due to the number, length and arrangement of tubes. The main plus: it's incredibly cheap!
Good solution: A Spearco or similar IC with a bar-and-plate core will provide a significant cooling of the charge air in the allotted space (about 31 inches from center of outlet to center of outlet; 33 inches from mounting tab to mounting tab). A unit to fit that space (about 28 inches long to account for the 90 bends needed to route the air) costs about $300-350. Drawback: Expensive...and long tubes mean more pressure loss (although not as much as a stock unit). This would require the fewest tubing fabs and would ensure an all-metal IC body, as opposed to the plastic tanked stock or Viggen unit .
I have the viggen ic running on some of my cars and it is VERY easy to put in but not that much gain. Remember cooler (bigger) is better!
I have a Viggen unit already.
That pic from speedparts if for the 9-3SS
I actually haven't payed off my head yet. I still owe $288 on it. :?
Discussion Starter · #17 ·
Thanks Mike, you know your stuff. I pulled that pic from Saab Central. Going back and checking it out, good correction your right it's Spearco. He even posted a site were he has his install. (http://www.vlphotos.com/saabvigic.html) While looking at the bar I see on the bottom, you think that bar can just be bent downwards?? If you bend it down just to move it out of the way. I don't know how hard that would be, because I'm not about to sacrifice my A/C. If that is possible to do, could you get an IC that would able be more then 6" in height? Let me know what you think.
HNNLIC
Snow, you could probably fit one that was 8'' if you bent the oil-cooler tube verrrrry slightly. Problem at that point is that the oil cooler tube will be below the bottom radiator mounting cross piece and you'll have fitment problems with the plastic air dams...but nothing that a dremel tool, or extra washers won't fix!
I'm thinking that the best dimensions might be 28'' long by 8 inches high. That would be just long enough to route rubber or silicone elbows around the radiator, without being tall enough to screw up the AC or the oil tubing......
The tube-and-fin IC in that link would probably work OK, but look for bar and plate if you can. There's a definite weight difference, as tube and fin is much lighter, but the mass of the bar-and-plate IC helps it act like a heat sink. I was looking to have one custom made by Bell Intercoolers, with the collection tanks on the top and bottom and the core arranged vertically (like a Procharger) but the minimum height was around 10 inches....
1 - 20 of 35 Posts
