1 - 9 of 9 Posts
Hey all, i have been getting coolant on my floor lately. Its right in the back of the motor by the alt. Would this leak be from my water pump?
Does anyone have a write up in the install?
Thanks
not knowing much if anything about the new Saab's i ask you this - where is the Water pump located on your motor - is it ANYWHERE near the leak? If it's not - then it's not that. How's the heater core ;) :lol:
the water pump is right there where the leak is coming from.
Where can i find the heater core?
HNNLIC
You may just have a slight leak in the hose. I was getting a "coolant level low" warning, a while before suddenly two hoses broke while doing some hard driving.
Depending on how many miles you have on your car, it may just be time to replace all the hoses (which is part of the scheduled services).
HNNLIC
Do you have a better (less contrast/ brightness) pic?
Discussion Starter · #7 ·
picture fixed.
Does anyone know what this is and if there is coolant lines there i should check?
I can't see anything... what color is the liquid?
My bet is on a tired clamp, or hose... maybe a leaky core which is in the dash where the coolant hoses go into the firewall.
Discussion Starter · #9 ·
it is the water pump.
It was leaking from the top and leaking down
Thanks for everyones help
1 - 9 of 9 Posts
