1 - 13 of 13 Posts
I know there are similar threads but i see that everyones situation is a bit different. Here's my situation and I hope you guys can throw me some info!
I have been driving my car with the "key not accepted" on the SID. I did this by bypassing the system by turning to the ON position, pressing a button on the fob, then turning the car on. I recently lost my set of keys(key and fob). Now I have a spare key and fob that came with the car. That fob never worked. I always thought the battery was dead. I replaced the keyfob battery. I heard you have to resync the fob to the car. So I tried pressing the unlock button multiple times with the key in and out of the ignition. I still didn't have any luck with cranking the engine. All lights, AC, etc turn on. He can i get this spare key/fob to work without spending hundreds or thousands at the dealer? I can't get the keys programmer to my car since my car is in my driveway. I don't want to spend $100 just to tow it to the dealer. I don't mind driving the car with the "key not accepted" message again. Any input would help. Thanks guys.
Unless you have the set of keys that work with the car already.
You're screwed. Sorry bud.
You need a TWICE unit with a fob and key thats programmed to that unit.
Discussion Starter · #4 ·
Illinois. This is not sounding good from the feedback im getting :( and my doors are unlocked so I can play with the ignition or battery or whatever i have to do to fix it.
Yahh your F$$ked, You need a Twice and some one to program it.
The only cheap way out is to find a friend in Australia, Australian market 93s-95s with out Theft security "The Twice" have a patch cable that goes in place of twice. This hasn't been available through Saab cars USA, I've tried it. Sorry Australia only. But its a simple connector to make the car run. I have seen Twice by passed by a Russian friend of mine but I've never tried it personaly. It can be done but the patch connector from an Ausi car would get you going again on the cheap.
Aussi parts link
SAABWRECK - For all Saab Parts
I think that could work.
Also, I've read that bypassing the lockout is super simple, I think its a ground cable that needs to be connected somewhere if i recall correctly.
Sorry thats all the information I have...I think this was in a thread about either push button start or remote start for saabs on this site.....my memory fails me...
Sometimes they work on their own, sometimes they need the immobilizer code programmed to the ECU with a Tech2. It kind of depends on what fault codes set in the old one, but clicking the remote at it might let you at least start it - you'll have to see.
Drew
correct me if im wrong cant the dealer order you a key with your registration?
Thats what mine always said whenever I asked about a spare key/remote, bring the registration and your drivers license, we have to order it from the factory. Or is it still programmed on-site?
key alarm
so long as the alarm is off you should be able to program the remote, but at the dealership. they've got the proprietary computer to do it. Or the knowhow, which i'd like to know.
I purchased a new keyfob from the dealer because I only had one and wanted to make sure I had a spare. They were able to program the computer. I don't know how. They connected the computer and had no problem programming the remote. I have a problem with my OBDII connector and the scanner I can't get working, but the dealer was able to program my new remote to the computer.
I thought the problem is when your car is locked and you try to unlock it without the remotes, then the system will lock itself out and then you need an entire new remotes, keys, and alarm box. But, if it's unlocked, you might need at least one key fob and you can reprogram new keyfobs and keys at the dealership.
1 - 13 of 13 Posts
