Car Aftermarket Amp in protection mode.
517 views 4 replies 4 participants last post by  IceTea
I have a 700 and a 400 watt amp in my 9000. One day the 700 amp stopped working. I checked everything! When i noticed it not working the speaker wires were unplugged in the rear. I hooked them back up nothing worked....
How can i fix this?
Do any of the amps work? Id check the fuses in the amp and your power wire. On most amps protect mode will come on when it overheats, the gain is on too high, or if the speaker wires short. Maybe something went wrong when your wires came off and it fried the amp.
like mentioned above it could be as simple as a bad ground
or if the speaker wires touched it could of popped a fuse on the amp which I would think is the most likely outcome. If the amp doesn't have any fuses it could of fried the amp..... just depends on the quality of the amp.
What kind of amps are they?
They are profile amps. California amplifiers, a 400 watt and a 700 watt.
